Counter/Timer
C++ with NIDAQmx library : I would like read counter's value.
In C++, I use the NIDAQmx library. I would like to know if it is possible to read the counter's value while counter runs.
For example:
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateCOPulseChanTime(taskHandle,"Dev1/ctr0","",DAQmx_Val_Seconds,DAQmx_Val_Low,1.00,0.50,10.00));
DAQmxErrChk (DAQmxStartTask(taskHandle));
while (!kbhit())
    // here, I would like to read the counter's value
    cout << "?????" << endl;
Sorry if I speak badly, English is not my first language.
Thank you.
(3,865 Views)
You can read the current count on an output task using:
DAQmxGetCOCount(TaskHandle taskHandle, const char channel[], uInt32 *data)
I hope this helps!
gus....
(3,851 Views)
It is exact. Thank you very much.
(3,842 Views)
