Counter/Timer
Calling Change Detection Timing event
Hi
Im using LabWindows CVI v8 and Im having problems with calling a function which contains the following standard CVI functions:
DAQmxCfgChangeDetectionTiming
DAQmxRegisterSignalEvent
The problem is I have put these in my own function of type    void functionname (); as shown below:
int CVICALLBACK starttestbutton_callback (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
     switch (event)
      {     case EVENT_LEFT_CLICK:
            function1();
            function2();
            etc
            functioname()
            function3();
            function4();
            break;
 return 0;
When the function is called by my code, the function is executed but it doesn't work properly as the DAQmxRegisterSignalEvent callback function doesn't get called. However, if I call this function directly from a user interface command button as shown below, it executes fine.
int CVICALLBACK StartCallback(int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
      if (event==EVENT_LEFT_CLICK)
      {     functionname();
      return 0;
Are there some restrictions as to how these standard CVI functions are called?
Any help would be appreciated.
Thanks Andy
Message Edited by Andy_458233 on 03-29-2006 05:02 AM
Message Edited by Andy_458233 on 03-29-2006 05:05 AM
Message Edited by Andy_458233 on 03-29-2006 05:07 AM
(3,801 Views)
I have found a way round the problem by calling my function from within the following if statement which is in the same place as the original function call:
if (event==EVENT_COMMIT)
        functionname();
  return 0;
It seems like the CVI functions require the return value or to be called by an event before they execute properly.
Message Edited by Andy_458233 on 03-29-2006 06:00 AM
(3,790 Views)
