Counter/Timer
USB 6009 Up/Down Counters
Hello to everybody,
I'm going to buy a USB 6009 for a low cost application and it fits my requirements except the counter.
In fact, I would need an Up/Down counter while USB 6009 has an event counter type only.
Do you know whether is possible to create the count direction by using one of the DIO bit?
I have been thinking to design an external circuit for creating the right signal but I have no idea for a while.
Please, let me know any suggestion.
Thanks in advance.
Regards
(3,886 Views)
These device can be used only for simple event counting using PFI 0 as an event counter input. The counter gate is not accessible on the USB 6008/6009 devices.
No Quadrature Encoder Capability is available: USB-6009 has counter. However, in DAQmx Base, externally controlled count direction is not supported. Notice that for a CI input task in the NI-DAQmx Base configuration utility, you can only specify count up. You cannot select "externally controlled." or "Count Down".
I hope it helps,
Marco
(3,853 Views)
