Counter/Timer
Capture quadrature encoder position on rising and falling edge using PCI-6602
The 6602 does support internal routing for most counter signals (refer to the device routes in Measurement and Automation Explorer).  However, the A, B, and Z encoder terminals are hard-coded on this device.
Best Regards,
John Passiak
Message 11 of 12
(2,791 Views)
OK,
Thats what I figured.
Based on my experimentation I have found that I am able to configure the sample clock for the various encoder counters to come from PFIxx.
For example this works:
DAQmxCfgSampClkTiming (  cthCounter1EncoderPosition,            // TaskHandle Task_Handle,
                                           "/Dev1/PFI1",                                   // char Source[],
                                          1000.0,                                             // float64 Rate,
                                          DAQmx_Val_Rising,                          // int32 Active_Edge,
                                          DAQmx_Val_FiniteSamps,                 // int32 Sample_Mode,
                                          NUM_ENCODER_SAMPS                 // uInt64 Samples_Per_Chan
Thanks for the help with this,
Kirk
Message 12 of 12
(2,787 Views)
