Counter/Timer
Channles mix-up in counter module 9361
I am using 9361 8ch counter modules to measure angular position of 4 encoders in Quadrature mode. I have 4 devices running in 2 test setups continuously, per device I run a separate thread in python to read the 4 signals from the buffer of the device, all devices are on a separate 9171 USB Chassis. Wiring from the encoders is through a 9923 DSUB to Screw Connector Block. In one setup 3 9171 chasis are on 1 powered USB hub. I sample using continuous sampling, and when taking a reading I read from the most recent sample backwards 200 samples.
In one of the 3 devices in this setup occasionally (3 - 4 times this year sofar) the channels are mixed-up, so the input signals appear in my software on another channel than expected (maybe circular shifted once or twice). In this case I need to reset the device to get it right again (meaning powering off and on again). This happens always on the same device, so 2 of the devices in this setup, and 1 in another single setup do not show this behaviour. Is this a known error in the device, and should I return it for repair, or is there another cause possible?
Frans
(2,638 Views)
Hi FransBosman,
I've found a Knowledge based article that might have to do with your situation. (Error -200524 Channels in Data Doesn't Match Channels in Task)
Would this be something that applies with your work?
Geo
(2,589 Views)
Hi Geo,
Thank you for your response, the article helps understanding the programming of the device, however, in my application I use the counter program that is built-in, using 2 digital input signals to measure angular position with the available ctr functions.
Thanks again!
Frans
(2,577 Views)
