Counter/Timer
Coax Line driver for pulse train generation
I wish to drive a 50 ohm terminated coax cable from the pulse train I generate with a daq counter/timer.  My understanding is this board is limited to around 25 mA of drive current, which is not enough.  Can you recommend any chips or preferably an 'eval' board I can buy to serve this purpose?  Does NI sell anything?  Thanks.
(5,800 Views)
Probably a 74HC(T)'140 or '244 with parralleled outputs?
Some more information about timing and output level needed would help.
Or
http://www.pulseresearchlab.com/products/linedrivers/prl-444/prl-444_main.htm
I would give a '244 a try..
Greetings from Germany
Henrik
LV since v3.1
(5,792 Views)
