Counter/Timer
Generate0-20V PMW-Signal
Hello everybody,
I am looking for a solution to generate a 0-20V PWM signal with NI-Hardware.
The Problem is that all NI-HW can generate signals between +/-10V. The solution will be a external signal conditioning. But I try to ask the forum members if there is a solution only with NI-PXI HW to generate a 0-20V PWM Signal without extern signal conditioning HW?
Thanks for your supporting!
Herati
(6,115 Views)
If you have a +-10V Signal you can shift it with a capacitor and a diode to -0.7(.5) and 19.3. However that will  not work with DC AND is external Hardware.
Maybe a 24V DIO Card?
Greetings from Germany
Henrik
LV since v3.1
(6,113 Views)
Thank you very much for your quick answer.
What about this PXI Hardware:
https://www.ni.com/en-us/shop/model/pxi-6624.html
If with DI/O so maybe with this one right?
https://www.ni.com/en-us/support/model.pxi-6232.html
Servus
Herati!
(6,111 Views)
