Counter/Timer
Continuous Buffered Period for Photon Counting
Hi everyone,
i'm trying to measure a continuous time trace of photon counts from a single-photon avalanche diode (SPAD) with a NI-6602 card. I'm using the DAQmxCreateCIPeriodChan function in the DAQmx_Val_HighFreq2Ctr mode (example  "DigPeriods-Buff-Cont-HighFreq2Ctr.c" from Nat. Instr.). I wired the SPAD to the PFI_39 input line, which is the default input line for DAQmxCreateCIPeriodChan. If i just try to read the ~100 counts/sec. "noise" (i.e. dark counts) from the SPAD  and read out the number of samples I get zero, although I'm using a measurement time of 1 second. Can anybody tell me what I'm doing wrong?
Regards, Christian W.
SOURCE CODE
int main(void)
    int         error=0;
    TaskHandle  taskHandle=0;
    int32       read;
    float64     data[100]={0};
    char        errBuff[2048]={'\0'};
    // DAQmx Configure Code
    DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
    DAQmxErrChk (DAQmxCreateCIPeriodChan(taskHandle,"Dev1/ctr0","",0.000001,0.100000,DAQmx_Val_Seconds,DAQmx_Val_Rising,DAQmx_Val_HighFreq2Ctr,1,4,""));
    DAQmxErrChk (DAQmxCfgImplicitTiming(taskHandle,DAQmx_Val_ContSamps,100));
    // DAQmx Start Code
    DAQmxErrChk (DAQmxStartTask(taskHandle));
    printf("Continuously reading. Press Ctrl+C to interrupt\n");
    while( 1 ) {
        // DAQmx Read Code
        DAQmxErrChk (DAQmxReadCounterF64(taskHandle,-1,10.0,data,100,&read,0));
        printf("Acquired %d samples\n",read);
        fflush(stdout);
Message 1 of 1
(6,096 Views)
