Counter/Timer
How to call DMA function to work with PCI-6602 counter in Labview
How can i use the DMA (direct memory access) in the labview? The hardware is PCI-6602 counter/timer board. What's the highest time resolution i can get from DMA? Right now i can run the counter down to 1 micronsecond for a measurement period of 1 second. Is it possible to push further down to 50 ns time resolution?
(5,256 Views)
Hi wtaurus,
The PCI-6602 has 3 designated DMA channels.  As long as you access those channels within the task in LabVIEW, you will enable DMA transfer.  Along those lines, DMA is a transfer protocol, and thus does not affect resolution.  The PCI 6602 has an 80 MHz timebase, and as such the maximum resolution you can achieve is 12.5 ns [1/(80*10^6)].  This information can be found in the specifications for the device found here.
David
David
Digital Multimeters
(5,239 Views)
Hi I'm trying to run a similar system. I can get down to 500 ns for a finite collection of points. Are there any examples out there that allow one to get down to 12.5 ns
(4,587 Views)
Hi ds10,
Would you please elaborate on your application?  What do you mean you can get down to 500 ns? What type of counter task are you performing?
Thanks!
David
Digital Multimeters
(4,561 Views)
Hi David,
I have a 6602 PCI counter/timer and I want to count how many TTL signals i recieve from a photodiode detector within a specified amount of time (bin time). So far I have set up my system as follows: I use an external clock and set it to a rate (1/rate=bin time) and then run a finite collection of edge counts. So far the lowest  bin time I can get before the computer gives me an error is 500 ns. Is it possible to get a lower bin time of 12.5 ns? 50 ns would be really great too! Thanks!
Cheers,
David
(4,558 Views)
Hi David,
To achieve the max resolution, the counter source signal (ext clock) will need to be 80 MHz.  What error is the computer throwing?  Thanks!
David
Digital Multimeters
(4,538 Views)
