Counter/Timer
Counting TTL signals from a single photon detector using 6014 cards simultaneously
INTRODUCTION:
I have two NI-PCI-6014 cards  (Dev 1 and Dev2 )and I'm trying to count the TTL signals coming from two Avalanche Photo Diodes (APD). For each photon detected, each APD generates a ~30ns TTL pulse. The frequency of pulses depends on the intensity of light the detector sees.So the signal frequency (random) can vary from 100Hz (dark counts, no light) to 1-5 Mhz
The critical thing in my application is that I need to be able to  count the pulses  at the exact same time bins (typically 1ms)  so that I can make comparisons between the signals detected by the  two detectors. There shouldn't be any unknown time delay between two time bins.
On NI-PCI-6014 cards, there are two counters and I guess it makes sense to use 2 counters on one of the cards as they would be on the same card.
As a starting point, I first wanted to count pulses from one detector.I tried to use "Count Digital Events- Finite-Buffered-Ext Clk.vi". I couldn't find a way to use the 20Mhz tiembase , but instead  generated a 10MHz digital signal using Dev1 and used this as the SOURCE of Dev2/CTR0 ( counter on second card) while connecting my data signal to GATE of the CTR0  as a Sample clock.
For low signal (less than about 30Khz), this worked, but beyond 30khz, I started to get error (200028).Then I started using "Count Digital Events- Continuous-Buffered-Ext Clk.vi". This time the treshold for error was about 300Khz, and I started to have errors: 200279 and 200141.
QUESTION:
Is it possible to count pulses from 2 APD's (random pulses changing from 100Hz to 1-10 Mhz) simultaneosly using one or two 6014's ?
Would I need some thing like 6601,6602 so that I use 2 counters for each APD, total of 4 counters  ?
Any suggestions from someone who might have some experience on this?
(4,469 Views)
Hi madigan,
I would recommend using two counters to measure the frequency of each APD. Using the two counter large range method, you should be able to cover the frequency span that you are looking at. The example which can help you get started is named Meas Dig Freq-Buffered-Cont-Large Range 2 Ctr.vi. This can be found in the Example Finder browsing by task under Hardware Input and Output » DAQmx » Counter Measurements » Digital Frequency. This will require the use of both of your boards for your two APDs.
Kent
(4,447 Views)
