Counter/Timer
DAQmx counter timebase error- 200140 returned when measuring frequency input
I am attempting to measure a frequency signal with DAQmx and receiving error 200140. The stated solution with this error is to use a faster counter timebase, but I do not know how to adjust.
(4,394 Views)
Are you using an external timebase source? What kind of frequency measurement method are you using (Low Frequency with 1 Counter, High Frequency with 2 Counters, Large Range with 2 Counters)? In traditional DAQ terms, this error means you received multiple edges on the GATE of the counter without receiving an edge on the SOURCE pin. How fast is the signal you are trying to measure? You can explicitly change the counter timebase source by settings two attributes: counter timebase source and counter timebase rate. These attributes are located in the channel attribute property node under
Counter Input->General Properties->Counter Timebase->Source
and
Counter Input->General Properties->Counter Timebase->Rate
I hope this helps.
gus....
(4,394 Views)
en el momento que trato de calibrar el osciloscopio me sale el mismo error pero no se donde encontrar las opciones que diste para resolver el problema, me peudes ayudar _-
(3,327 Views)
