Counter/Timer
edge counting inaccurate
I'm getting inaccurate results from my USB-6210 edge counting check from MAX. I have a TTL source that generates four pulses that is connect to PFI0 through a simple RC filter (390 ohm and 0.02uF). I start the edge counting from the test panel in MAX choosing PFI0 as the edge source. When I trigger my four pulses I receive a much larger count (sometime up to 20 counts) from the MAX test panel. Only when I remove the RC filter do I receive an accurate count (4 pulses exactly). I need to use the RC to filter out some 45KHz noise generated by another piece of equipment in the lab. I know I can set up the USB-6210 to use a time-based filter but I thought a simple RC filter would be a quick solution.
I have tried this with a USB-6211 with the same results. Only the USB-6009 preformed as expected with accurate counts. The USB-6009 edge count is not affected by the RC filter.
Any thoughts?
(6,170 Views)
A filter like that produces a very slow (by logic standards) "edge." The time constant of the filter is about 8 us. Logic devices like risetimes in the nanosecond region. Logic devices have a linear region and while in that region very small amounts of noise, including internally generated noise in the logic IC itself, can generate false outputs. If the time-based filter will work for the frequencies involved, it is almost certainly the better choice.
Lynn
(6,165 Views)
Agreed, but I'm assuming that the input should have a hysteresis mechanism (schottky) so that it would be unaffected by the noise in the linear region. It is interesting that the filter works perfectly on the USB-6009.
(6,163 Views)
@goldenrad wrote:
... I'm assuming that the input should have a hysteresis mechanism ...
It doesn't :(.  You should use the digital filter.
It's probably a bandwidth issue, there's no hysteresis on the 6009 inputs either.  The 6009 event counter can only count up to a 5 MHz signal according to its specificaitons.  The 6210 however supports an "external base clock frequency" of up to 20 MHz.
Best Regards,
John Passiak
(6,153 Views)
Okay, thanks for the information. I'll implement the digital filter.
(6,143 Views)
