ā01-16-2010 05:43 AM
I am using a PCI 6602 card to do pulse width measurement. Using the standard "Meas Pulse Width-Buffered-Finite.vi" program. The average running time of this VI
is 13 millisecond. Does anyone know how to make this vi to run faster because I need to put it inside a for loop with N=10000. Thanks.
You can find this VI with the "Find examples" option from LabView.
ā01-16-2010 11:16 AM
ā01-16-2010 09:09 PM
I tried to only put the DAQmx read inside the for loop, but it gave 0, no counts. Only when you put the whole VI inside the loop, it can work.
Yes, I mean the whole VI running time is about 13 ms, want to make it shorter.
ā01-17-2010 12:23 AM
