Counter/Timer
Different Counter Outputs with different number of samples
I´m using an 6602 Timing I/O Board and/or a MIO 6281. For timing control of our measurements I use different counters from both boards triggered by a Digital Out for synchronization. The counters are set to CO Pulse Time, implicit timing, digital triggered and finite sample mode.
Lets assume I use two Ctr´s from the 6602 board. My problem is when setting the number of samples from only one CTR to another value then the second I´m getting an error. The rest works perfect, I can use different starting delays, low or high times, only different sample amounts don´t work. It´s regardless if I use the Timing I/O or Multi I/O board.
For example:
                             _ _       _ _
Ctr 0 / 6602 _ _ |     |_ _|     |_ _  --> 2 samples
                             _ _
Ctr 1 / 6602 _ _ |     |_ _
Somebody any idea or advice?
(6,909 Views)
Here is my currently used code, perhalps it helps you understanding the problem. Both are doing the same but one is a bit optimized. Hopefully someone can help.
(6,889 Views)
Accepted by IngoH
two counters are used for a fenite pulse generation. Please see the link below.
Link:
http://digital.ni.com/public.nsf/allkb/9D1780F448D10F4686257590007B15A8?OpenDocument
For example you could use Ctr0 and Ctr2.
Regards
Rüdiger
(6,841 Views)
If all solutions would be so simple, thanks!
(6,751 Views)
