Counter/Timer
Does the SOURCE signal must be a period signal?
Hi
I am using a 6602 broad for counting events
I wanna count the random signal(B) in each period of an period-signal(A), from a specified time.
The first plus of the signal B trigged the counts.
So I set signal B as the gate, and set signal A as the SOURCE. The mode is "bufferd period measurement".
But the error 10920 always occurs, and the counts have recorded are totally wrong.
When I set signal A as the GATE, and set the internal timebase as the SOURCE, the error disappears.
But using this setting, I cann't specified the trigger time.
So, is my error caused by setting the random signal as the SOURCE ?
How can I imply all my request.
(3,614 Views)
Shireman
When you say the "mode" is "buffered period measurement", do you mean that the program you are using is the example program "Measure Buffered Period"? If I understand your question correctly, this example program should be applicable to what you are trying to do.
The "Measure Buffered Period" example program has the following description:
DESCRIPTION:
This VI counts a series of pulse periods and stores them into a buffer, using an NI-TIO based device (e.g.: 6602). The counter increments its count everytime a pulse comes into its source input, and transfers that value to memory upon every time a rising edge comes into its gate input. After the counter value is stored in memory, the counter is reloaded with a zero. The data in memory is rea
d continuously in the while loop, until the Stop button is clicked or an error occurs.
So if you want to measure the number of pulses of signal B in one period of signal A, you would wire signal B to the Source, and wire Signal A to the Gate.
Russell G.
(3,614 Views)
Thank you very much. Mr. Russell
Exactly as you say, I use the example of "Measure Buuffered Period". But there is something strange: when I set the Internal Timebase as the source, the frequency is 20MHz, everything runs right. But when I use signal B as the Source, whose frequency is about 10kHz, 10920 error occurs. I know that error occurs when the DMA bus is busy. But my question is why this doesn't happen when I use the Internal Timebase, whose frequency is much higher than the signal B. Is the reason is the signal B is not a period signal? So what can I do?
(3,614 Views)
What is the frequency of your Gate signal? Due to the source time base limitation, the gate signal must have a pulse width of at least (1 / source frequency). For example, if using the time base of 10 kHz as the source, the gate pulse width must be greater that 100us in order to register a count. Since your source signal is not periodic, I would recommend a gate signal of much less than 5 kHz.
Do you get the same behavior if you use a different counter?
Here is a link that has more information on this error. You may have a noisy source signal.
Russell G.
(3,614 Views)
