Counter/Timer
E-series counter
Hi, evry!
The task is to measure time interval (around 10 ms) between rising edges of two different digital lines.
How can this be done using 6052E card?
Thanks in advance!
(6,456 Views)
OK, let's put it another way.
As E-series documentation declares, there are two triggering actions associated with each counter: Start trigger and Pause trigger.
How to connect these two triggers with two PFI lines (if it is possible with E-series DAQ card)?
Thanks.
(6,437 Views)
Accepted by JungleBoy
Hi JungleBoy,
Please take a look at this example from the Example Finder: Meas Two Edge Separation. You can use the Gate and Source of a single counter to measure the time between a rising (or falling) edge of a signal with respect to the falling (or rising) edge of another one. This example can be found in Help » Find Examples » Hardware Input and Output » DAQmx » Counter measurements » Two-Signal Edge-Separation.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(6,427 Views)
Ah, it turned out to be easier than can even be thought!
Thanks, REDS!
(6,421 Views)
