Counter/Timer
Frequency divide by N doesn't work on Counter-Timer PCI-6602
Hello everybody,
I tried to do something basic ( ?) with this Counter-Timer 6602 Board, and it doesn’t work.
So I hope some people with more experience than me could understand what happens here.
1) What I need:
I need to generate 4 synchonised clocks, whose periods will be multiple of 1 ms.
2) What I have:
LabVIEW 7.0 and a PCI-6602 Counter-Timer Board in a DELL PC running under XP pro.
The PCI-6602 Counter-Timer Board has 8 counter timers named CTR 0, CTR 1, ... CTR7.
3) What I have already done, and that worked:
- Generate a 1 kHz “Master Clock” signal from CTR 4, configured by “Continuous Pulse Generator Config.vi” (found in “Data Acquisition, Counters...).
- configure CTR 0 and CTR 1 to work as frequency dividers, by use of “Down Counter or Divider Config.vi”.
- Apply the output signal of CTR 4 (OUT ) to the SOURCE inputs of CTR 0 and CTR 1 by means of physical wiring in the SCB-68 connection box.
When I do this, I get two nice secondary clock signals on my oscilloscope screen, ( with periods = 3 ms, or 5 ms or whatever multiples of 1 ms I choose) from CTR 0 and CTR 1 outputs , very clean and perfectly in phase with the 1 kHz Master Clock.
So far, so good...
But I still need 2 more secondary clocks...
One would say: “No problem, do the same trick with two other counters...” Well, not so simple, it seems...
4) What I tried to do, and that didn’t work:
When I try to do the same frequency division with any of the remaining counters, (CTR2 to CTR7), the program stops and I get an error “ –10020 : Time base not valid “.
I can’t figure out what happens here: I thought any counter could be configured to work as a frequency divider, but it seems not to be so, and I am stuck here.
Has anyone an idea about how to fix this type of problem?
Attached file: hor_div02New.vi
(3,786 Views)
Bonjour,
L'utilisation du VI Down Counter or Divider Config n'est pas possible avec la PCI-6602.
Ce VI est en effet adapté à d'autres types de cartes. (Cartes basées sur le chip DAQ-STC contrairement au NI-TIO de la PCI-6602)
Vous trouverez plus de détails sur ce point au lien suivant :
http://digital.ni.com/public.nsf/websearch/EFBA8B2BD464261686256B04004F7C88?OpenDocument
Salutations,
Marc L.
NIF
(3,733 Views)
karolik,
I'm just adding a followup in English. As Marc L. mentioned, the particular vi named "Down Counter or Divider Config" isn't compatible with the 6602. While the 6602 does have the ability to generate 4 synchronized clocks, a different syntax is needed. Here's how I'd do it:
Traditional NI-DAQ
1. Configure a continuous pulsetrain on CTR 4. Route its output to, say, RTSI 4. Don't start it yet.
2. Configure CTR 0,1,2,3 for continuous pulsetrains using RTSI 4 as their "timebase source." Start them.
3. Start the CTR 4 pulsetrain.
4. Now CTR's 0-3 should generate separate clocks with synchronized phasing.
DAQmx
1. Configure a continuous pulsetrain on CTR 4. Don't start it yet.
2. Configure CTR 0,1,2,3 for continuous pulsetrains using "Ticks" for units. Use a DAQmx property node (probably Channel property node, but am not 100% sure and don't have a LV PC handy to check) to specify that the "ctr4 internal output" should be used as the timebase. Start them.
-Kevin P.
(3,720 Views)
