Here are the facts:
My goal is to decode a GPS Time from a GPS card but here are the facts:
I am running a PXI-1000B chassis using LabVIEW Real Time OS. I have a
PXI-6608 Timing Module in Slot 2 and a Symmetricom bc637C PCI GPS card
in slot 6. I wire the DC Level IRIG-B signal from the GPS card to the
PXI-6608 into pin 15 (PFI7) on a terminal block. I wire the ground to
pin 14.
Then I run the "Measure GPS Timestamp.vi" with the LabVIEW target as the PXI chassis. The settings for this VI are
      GPS Counter = Dev1/gpsTimestampCtr0
      GPS Synchronization Method = IRIG-B
      Synchronization Source = PFI7
I do not get valid information and even if I remove the terminal block
from the 6608 card, the result (seconds) is not influenced. It appears
that the GPS signal is not being seen.
Any suggestions?
Thanks.
Michael Froehlich
