Counter/Timer
Generate a different width pulse using pxi-6542
Hello I want to use the board of PXI-6542 to generate a waveform, and the waveform has different width, but the width is a integer which is less than ten  is multiplied by 0.1ms,and the multiply is random. The waveform is output through PXI-6542.Thank you for your help.  bless vivian
(3,734 Views)
(3,719 Views)
