Counter/Timer
HP 53131A LabVIEW VISA 7.1 driver
Could someone send me the old LabVIEW VISA 7.1 driver for HP 53131A counter?
Miklos
(6,387 Views)
Hi Miklos,
Feel free to use our 3rd party instrument driver network 🙂
http://www.ni.com/downloads/idnet/
Put in the search area: 53131A
And you'll get to this page: http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1003
The oldest supported LabVIEW version is 8.0
There is two options for the drivers: project style and plug and play. Since in LabVIEW 7.1 doesn't support projects, I suggest to use the LLB style plug and play driver.
I made for you a version conversion from 8.0 to 7.1. See the attachement.
But the MNU file, which puts the VIs into the LabVIEW palette cannot be not converted. So you can use the VIs, as they are and if needed you can put them into the palette manually.
I don't take the responsiblility if it doesn't work since we support the driver only from LabVIEW 8.0, and only the project style driver.
However I hope it will work for you.
You need to have installed NI-VISA 3.2 or newer.
Best Regards,
Tamas
(6,382 Views)
Many thanks for you Tamás!
Köszönöm!
(6,378 Views)
