Counter/Timer
Help with internal signal routing on a 6602
I need to do the following with a 6602:
GPIO (any) to RTSI0
4 Counter Outputs to RTSI1-4; doesn't matter which.
I have tried P0.0->RTSI0 and then CTR0-3 to RTSI4.  But I get an error that the resources required for the last connection (CRT3_OUT -> RTSI4) are being used by the P0.0->RTSI0 route.
What are the rules?  Acording to the routing chart, they are all possible, but I don't know how to keep them from bumping into one another.
(5,655 Views)
Hi:
How is it that you are doing the routing? DAQmx eport signals? DAQmx connect terminals?
Can you give us a little bit more background on what you are doing?
Have you this article?
(5,628 Views)
