Counter/Timer
Register information on X series driver for encoder
Hi All:
I am working on the X series driver development by using MHDDK. After comparing M series and X series I found that theere is a Gi_Save_Trace bit in register Gi_Command_Register in M series. When it is set, the register goes into the latched mode after the next clock edge to assure valid data was latched. However, I can't find equivalent register bit in all X series counter registers.
Can anyone tell me what is the equivalent register bit for same function that Gi_Save_Trace does?
Larry
(6,008 Views)
Another related question is that: what is the equivalent register bit in X serires counter registers for Gi_Alternate_Sync in Gi_Counting_Mode_Register in M series?
Larry
(6,006 Views)
Hi Larry;
I think it would be more useful for you if you post your question in the Driver Development Kit (DDK) here.
(5,989 Views)
Hi PedroMunoz,
Actually, I wanted to post it at DDK forum. I don't know why it is shown here. I may need to do it again.
Larry
(5,983 Views)
