Counter/Timer
Hex decimal n.o to integer conversion?
how to convert 1 byte hex n.o in decimal form to the decimal integer of of 8 bit data .
(6,623 Views)
Accepted by PnRaja89
You can use the Hexadecimal to Number fucntion. This is available in - Programming>String>String/Number Conversion.
Alternatively you can search for hexadecimal to number conversion.
Kanchan Bhakoo
Applications Engineer | National Instruments
(6,615 Views)
can u show that with help of example please i am not able to get that function
(6,609 Views)
Hi mai,
Just have a look at the attached screenshot. This should clear things up.
Cheers
Gautham
(6,598 Views)
