Counter/Timer
How Do I match counter to PFI in NI 9401
I would like to know which counter corresponds to which PFI in NI 9401
I have looked and have not find it in the 9401 data sheet.
Thansk!
Gil,.
(2,159 Views)
Accepted by gilmaor1
Each line of the 9401 can function as a PFI line, PFI0 is DIO0, PFI1 is DIO1...
when you configure your counter task, use a DAQmx Channel property node to
tell the task which PFI line to use as an input to the counter.
(2,113 Views)
OK
Thanks!
(2,104 Views)
