 mojeda
			mojeda
			08-03-2005 06:39 AM
 falkpl
			falkpl
			08-12-2005 08:15 AM
Can you give a little more detail? Push a button, I am assuming this is a physical button (not a software button), what signal does your button produce. If you can get it to produce a clean ttl/cmos rising edge for each time it is pressed, you can do some simple edge counting. You can even prototype this in MAX in just a few seconds before coding it. What counting hardware do you have, and what software are you developing with? this should not be too hard of a task.
Paul
08-17-2005 04:15 AM
 falkpl
			falkpl
			08-17-2005 11:10 AM
