Counter/Timer
How do I make a counter PCI 6601 read more than 1 channel?
I have a PCI 6601 board and I am reading a Magnetic Hall Effect Speed Sensor. I am able to read 1 channel but would like to read all 4 at once how is this done in LabVIEW? I am using this example attached below. Also I would like to have the 2 examples below combined into 1 can this be done and how?
(3,556 Views)
1) Put more than one counter in your group. Each counter will perform the same operation.
2) Your second vi (Tigear_sub.vi) is missing a subVI. But, if you just want to combine the two, stick them both on the same block diagram. You will have two parallel loops.
(3,556 Views)
What do you mean by putting more tha 1 counter in my group? Do you mean doing a diagram for each counter?
(3,556 Views)
