Counter/Timer
Can the counters on the NIDAQ 6602 all use different clock speeds simulataneousl
I am collecting data on 4 channels using event counting on 4 seperate counters. All these counters are on one NIDAQ 6602 board. All counters are using the onboard clock.
Can I make each counter use a different clock speed if I am collecting data simulataneously on all channels?
Example:
Channel 1 - 20MHz
Channel 2 - 80MHz
Channel 3 and 4 - 100kHz
(3,590 Views)
Rink;
You can definitely do that. Just specify the needed timebase by counter, and shouldn't see any problems.
Regards.
Filipe A.
(3,590 Views)
Thanks, Filipe!
rink
(3,590 Views)
