Counter/Timer
Replacement for PC-TIO-10
I am currently using a PC-TIO-10 in an application on a Windows 95 xox. I want to upgrade my control system. I cannot get my Windows 2000 box to recgonize the PC-TIO-10. Is there a PCI replacement for this card?
(3,905 Views)
You should be able to get your Win 2000 machine to recgonize your PC-TIO-10 board. You may have a bad installation of NI-DAQ. I would suggest uninstalling NI-DAQ, take the board out of the computer, reinstall the latest version of NI-DAQ from ni.com. Then follow the procedure here to configure the board.
http://ni.com/support/daq/board.htm
There is a PCI counter board that you could replace the PC-TIO-10 board. It is the NI 660x board, there are three different versions. I would suggest taking a look at either the PCI-6601 or the PCI-6602 boards linked below.
PCI-6601
http://sine.ni.com/apps/we/nioc.vp?cid=3589〈=US
PCI-6602
http://sine.ni.com/apps/we/nioc.vp?cid=1123〈=US
Let me know if you have any questions about these two boards.
Br
ian
(3,905 Views)
