Counter/Timer
How do I read 2 counters simultaneously using a PXI-6052E board?
Labview help files seem to suggest that I should be able to use the "Group Config" vi to configure 2 counters within a single task ID so that I can read both counters simultaneously with a single read command, but I am having trouble doing this so far.
The only way that I can read both counters is to run the group config vi two times, creating two separate task IDs. For each task ID, I can then run "Set Attribute" to set the attributes of the counters, and then "Get Attribute" to actually read the counter values.
I need to configure the two counters separately (so that each looks at a different input), but I would like to be able to arm them and reset them together.
Any help would be greatly appreciated! I've seen example vis that read them sequentially (in the way that I am doing now), but Labview help suggests that the "Group Config" vi can allow you to group several counters together so that you can address multiple counters with a single read command.
Polly
(3,183 Views)
Hello Polly. Thank you for contacting National Instruments. If you right click on Group Config.vi and select Help, LabVIEW Help will open up. The description of the VI says, "Groups with multiple counters are not currently supported by MIO-16, E Series boards or NI-TIO-based devices." Some legacy boards that we don't sell anymore used to support this, but most of our current boards do not. The best way to do what you want is to configure one counter and then just copy and paste it to make the second one. Please let me know if you have any questions. Have a great day!
Marni S.
(3,177 Views)
