Counter/Timer
How do I record the position of event pulses between reference pulses?
The reference pulses are distance markers and the event pulses are random fault signals that need to be located distance/time wise with respect to the reference pulses on a continuous basis. The maximum frequency of the reference pulses is 10HZ. I am using Labview on NT4 with 6601 counter and 6023 DAQ.
(3,635 Views)
With the 6601, you can use buffered period measurement. This application will count pulses from the internal timebase and every time a rising/falling edge comes in on the gate of the counter, it will get the current count value.
There are examples of this in LabVIEW and using NI-DAQ function calls. Let me know if you have any problems implementing this.
Brian
(3,635 Views)
I have tried to use the buffered period measurement with the counter source set to the internal 100KHZ ref but I have two external pulse sources - the reference pulses that are the regular timing pulses (max 10HZ) and the event pulses which I am trying to measure the position of with respect to the reference pulses. I can't feed both into the gate input without external hardware or can I? The application is a bit like the 'buffered two edge separation measurement' but this only captures one edge on the gate and needs another transition of the aux line to make another measurement whereas I can have none or one or more transitions of the gate (gate) in between each reference pulse (aux line).
(3,635 Views)
