Counter/Timer
Please, Where can I find examples of C code programs about register-level programming of National Instruments DAQ PCI MIO 16E-4?
I found only examples of pseudo-code programs (about register-level programming of DAQ MIO 16E-4), but not examples of C code. Can you help me, please? Where can I find this material (eventually even only documentation) ?
(3,778 Views)
If you go to www.ni.com/support there is a link to Example codes, where you will be able to search for various examples.
Here is a link to an example
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/3903b7680568a07c86256907004fa052?OpenDocument
also the following Knowledgebase would be very useful it is 'DAQ Register-Level Programming Resoruces' page
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/b08f4125a9325b3f862565cc0073e68f?OpenDocument
Good Luck,
Shruti T
(3,778 Views)
Well, as you may have noticed, Register-level programming is much more difficult than using NI-DAQ, and it should be avoided unless absolutely necessary. But, if by any reason you need to use this type of programming, I would advise you to visit the following link:
Data Acquisition Register-Level Programming Resources
Good luck with your project!
(3,778 Views)
