Counter/Timer
How do program 3 independent finite pulse train generators from 3 counter pairs
I need to drive a 3-axis piezo leadscrew friction type motor by finite train of pulses from a PCI-6602.How do I specify the counter pairs in my code with out any one counter conflicting with the others?
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
(3,472 Views)
Hello;
You can definitely use one of the shipping examples that comes with your Software, and expand that concept to three counters. One counter won't interfere with the ohers. You just need to configure three independent tasks, each one for one counter.
If you are using Labview, you can create a dependency on the configuration of the counters by using the error cluster from one VI to another.
Regards
Filipe A.
(3,472 Views)
This scheme (and the examples) works fine when you want finite generation done in sequence, but seems not to work with when they are done independently and in synchronously run in parallel fashion.
Berns B.
(3,472 Views)
