Counter/Timer
How do you generate pulse output from compact RIO modules
I need to generate a single pulse output using a compact RIO system.
The pulse will go to a valve driver board to send a pulse to open or close a valve.
The pulse length should be variable between 10ms to 200ms and also have the option to hold it on for up to 60 minutes.
I currently use compact fieldpoint and a counter module cFP-CTR-500 which works well fo my application but need to do the same in Compact RIO.
The modules I have in the system are:
NI9476 Digital output
NI9265 Analog output
NI9425 Digital Input
NI9205 Analog Input
I am using the expansion racks NI9148 to hold the module and this is driven direct from the network and no controller is used.
I do not have FPGA so not sure what the best way to do this is.
I guess I could have one compact fieldpoint rack and the 500 counter module but would like to keep it in RIO if possible.
Any ideas.
Message 1 of 1
(5,719 Views)
