Counter/Timer
How to generate a TTL pulse whose frequency should be N times slower than a input TTL pulse (DAQ NI USB 6259)
I have an DAQ NI USB 6259.
I receive input TTL pulses with freq 25 Hz. I would like to create an output pulse 5 times slower than the input pulse. Is this possbile to achieve?
(6,118 Views)
Yes, absolutely.  Here's an example to get you started.
(One small note: when you divide by an odd number like 5, this method won't produce a square wave out with exactly 50% duty cycle.  In many (most?) apps, this isn't really a concern because only the rising OR falling edge really matters.  But just in case, I wanted to mention it.)
-Kevin P
(6,110 Views)
