Counter/Timer
How do you measure frequency using the onboard counter on PCMCIA 6024-E
I am using LABView 6.1 and NI-DAQ 7.2 with a SCXI-1000 chassis and a PCMCIA 6024-E on a laptop. I need to measure a frequency of about 3KHz and would like to do that using an 1180 direct through connector.
Firstly, should I see this 1180 in MAX like any other module?
And secondly, how do I use this 6024-E card to measure frequency? Which pins are supposed to be used on it to measure, and will I see the counter run in the test window in MAX according to the frequency measured?
I know NI also have a frequency module for the SCXI chassis. So lastly, will it be better to use that, rather than measure directly off the 6024-E?
Any help, advise or comments will be greatly appreciated!
Thanks!
(3,471 Views)
I think I can help out with some of your questions. First, the 1180 module won�t show up in MAX since it is really just a feedthrough cable which allows you access to your unused signals from the DAQ card.
You definitely can measure frequency using your 6024E. An example installs with NI-DAQ 7.2 which shows how to accomplish this. To access this example go to the LabVIEW start up screen and hit the Find Example button. When the Example Finder opens up browse to the following location: Hardware Input and Output -> DAQ -> Counters -> DAQ-STC -> Measure Frequency (DAQ-STC).vi
This example measures frequency and has a connection diagram on the front panel. The documentation for the example can be accessed by going to File -> VI properties -> Document
ation, after you have opened the VI.
You are correct that we offer a frequency input module for SCXI (SCXI-1126). This module would be useful if your input voltages are non-TTL, or if you need to measure more than one channel of frequency signals. This module has an input range of +/- 250Vrms and 8 input channels.
I hope this helps! Let me know if there is anything I can help with or clarify.
Ken S.
Applications Engineering
(3,471 Views)
