Counter/Timer
What is the input impedance on the new NI 6624 counter/timer devices?
On my 6602's specs, I've found that its input impedance is 25k (ohm) to 500k (ohm). I couldn't find this data on the new 6624's specs. Is this data avalilable? Thank you.
Daniel Ramirez
Chile
(3,457 Views)
The input impedance of the 6624 is variable versus applied voltage since it consists of a current limiter. For example, at 5V the current can be anywhere between 2.2 mA and 10mA so the impedance would be 5 divided by the current value (500 to 2.3k Ohms).
Hope this helps.
gus....
(3,457 Views)
