Counter/Timer
How many encoders ?
From how many encoders may I read using a PCI-6601 ?
Looking in the user manual at the description of the PFI lines in the motion encoder context, after Channel_A, Channel_B and Index/Z I can see some paranthesis from (0) to (3).
Does this means that I can read from four encoders ?
Tom
(4,467 Views)
Hi Tom
There are four counters(counter 0, counter 1, counter 2, counter 3) in PCI-6601
●LV Version:LabVIEW7.1
●OS:WindowsXP(SP1)
●Hardware:PCI-7344, PCI-6602, PCMCIA 6024E
(4,465 Views)
Thank you. I saw four counters but how many encoders (each one for example with A and B signals) can I connect to the board ?
What if the encoders have A, B and Z signals ?
How do I make the connections ?
Tom
(4,506 Views)
Hi Tom,
You can use one encoder for each counter on the board.  In your case, the 6601 has 4 counters, so you can use 4 encoders.  You can find more information on encoders and this board by looking at the following links or searching 'quadrature encoder' on Ni.com.
6601/6602 User Manual
(4,446 Views)
Hi Otis,
Thank you very much for your answer, now it's clear for me.
Happy New Year !
Tom
(4,442 Views)
