Counter/Timer
How to build a duration counter between events
Hi
Im learning LabView and have to do this exam:
1. Turn on LED A, then turn on LED B .
2. Turn on Beep then turn off Beep ( How to make beep in VI ?).
3. Count duration time in 1 or 2 (about 100-1000ms).
I use LabView 8.6.
4. How to start "Tic count" function by a control?
5. How to build "Run Button" instead of Run Toolbar.
6. How to build a project to *.exe that when it run the front panel will not appear the menu and toolbar
Please help.
Thank a lot
PiterChange
(6,003 Views)
Hi PiterChange,
I must stress that the forums are not intended to get solutions to homeowrk or test problems, but a place to receive help/feedback on topics you are struggling with.  A good starting point for getting started in LabVIEW is found at www.ni.com/gettingstarted
Please take a look at these resources as well: http://www.google.com/search?q=learn+labview&sourceid=ie7&rls=com.microsoft:en-us:IE-SearchBox&ie=&o...=
Best,
Adam
Academic Product Manager
National Intruments
(5,982 Views)
