Counter/Timer
How to program the daq card to route signals?
I would like to program the daq card to route signals, for example from DIO0 to
DIO1. All this should happen without Labview, directly on the board. Is this possible?
What I want to do, is to get a lot of signals as inputs and output those
signals as they are. Sometimes I need to take one signal through Labview
and make some modifications to it. If I route all the signals through Windows
and Labview will propably cause latency, so I would like to do this at the lowest
level as possible.
Currently I'm using PCI-DAQ 6025E, but this card might not be sufficient for our
needs, so if this is possible with some other card, please share your information.
All information on this matter is highly appreciated.
(3,662 Views)
Oops!. I just noticed that I accidentally posted this question to the wrong forum.
I posted a new one to "multifunction DAQ", so if you have something to say about
this matter, then go here
http://forums.ni.com/ni/board/message?board.id=250&message.id=31100
Thanks.
(3,651 Views)
(3,648 Views)
