Counter/Timer
How to read external triggering count with DAQmxReadCounterU32?
I'm uing PCI-6025E board and checked MAX can count DMI counter connected in /Dev1/PFI3 of ctr0.
But when I use DAQmxReadCounterU32 function in example code, it returns 0 of 'read' integer value but doesn't show the number of counting.
The example code is:
 DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
 DAQmxErrChk (DAQmxCreateCICountEdgesChan(taskHandle,"Dev1/ctr0","",DAQmx_Val_Rising,0,DAQmx_Val_CountUp));
 DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"/Dev1/PFI3",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
 while(1) {
  DAQmxErrChk (DAQmxReadCounterU32(taskHandle,-1,10.0,data,100,&read,NULL));
  printf("\rAcquired %d samples",read);
  fflush(stdout);
I set the second parameter of DAQmxReadCounterU32() as -1 to read infinite DMI counting.
How can I read the DMI counting just like MAX does?
I'm converting DAQ to DAQmx..from Parkoz.com
(4,220 Views)
Hi anarkie,
This thread addresses your issue, and should be of some help.
David
Applications Engineer
Digital Multimeters
(4,202 Views)
