Counter/Timer
Measure Pulse Width or Period VI gives inconsistent pulse widths
Using NI 6036E board, this VI gives me accurate single pulse width measurements most of the time, but not always. I suspect noise is falsely gating the measurement either on too soon or off too soon. I am measuring a TTL signal. I see some noise using an oscilloscope but it doesn't seem to be enough. Anyone know what the gate thresholds are for the counter gate inputs? Do people normally install a schmidt trigger or other signal conditioning in front of the incoming signal? Or has anyone come up with another solution?
(3,498 Views)
User manual (page A-6 Timing I/O) --> TTL compatible
I normally use a schmidt trigger with a RC lowpass filter on its output.
The PCI-6602 counter board has onboard digital filters.
(3,498 Views)
