Home
Community
Discussion Forums
Most Active Hardware Boards
Counter/Timer
Topic
Counter/Timer
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
ND_counting_synchronous parameter value
Walter Tansini
01-21-2004
02:10 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to do synchronous counting on a PXI 6602 card by setting the ND_COUNTING_SYNCHRONOUS parameter with the GPCRT_Change_Parameter function.
What are the parameter values for this function (to turn it on or off), for I can't find them in the Traditional NIDAQ reference
0
Kudos
Message
1
of 2
(3,490 Views)
Reply
Re: ND_counting_synchronous parameter value
Spencer S.
Active Participant
01-22-2004
10:19 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Walter,
To enable synchronous counting, the
GPCTR_Change_Parameter
function should be called with the following parameters:
paramID = ND_COUNTING_SYNCHRONOUS
paramValue = ND_yes
Good luck with your application.
Spencer S.
0
Kudos
Message
2
of 2
(3,490 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
