Counter/Timer
ND_counting_synchronous parameter value
I want to do synchronous counting on a PXI 6602 card by setting the ND_COUNTING_SYNCHRONOUS parameter with the GPCRT_Change_Parameter function.
What are the parameter values for this function (to turn it on or off), for I can't find them in the Traditional NIDAQ reference
(3,461 Views)
Walter,
To enable synchronous counting, the GPCTR_Change_Parameter function should be called with the following parameters:
paramID = ND_COUNTING_SYNCHRONOUS
paramValue = ND_yes
Good luck with your application.
Spencer S.
(3,461 Views)
