Counter/Timer
NI 9361 enabling pull up labview property node
Using The DAQmx Channel Property Node, I do not see the options that are listed in the NI article NI 9361 Will Not Enable Differential or Pull-Up Resistor Mode - NI
I cannot figure out why I am not able to set the pull up resistor/logic level behavior as shown in that article. What am I missing?
(2,937 Views)
Accepted by ArieSafari
Make sure you are adding your 9361 to the physical channels input of DAQmx Create Channels VI as well. Otherwise, the property node might filter out the unsupported properties.
https://tmesystems.net/
(2,920 Views)
Yes, I was able to find the logic level behavior option once I replaced the channel input on the block diagram.
Now I need to figure out what else is wrong, because It is still not counting correctly. I have a device that uses a hall effect sensor. When I spin it with my hand, I get nonsense counts.
(2,827 Views)
