 Jesus_V
			Jesus_V
			08-18-2005 04:28 PM
08-21-2005 07:12 PM
Hello Jesus,
Four seconds seems slower than normal. Do you have this delay with an example from the Example Finder? (Help menu>>Find Examples) Browse Hardware Input and Output>>DAQmx>>Generating Digital Pulses.
What DAQ board are you using? What is your operating system? What version of DAQmx are you using?
08-23-2005 06:09 PM
Thanks Marni. I'm using a PCI-6602 Timer/Counter board on Windows 2000, NI-DAQmx v7.4, but I've tried it also in my laptop with a DAQCard-6062E and got same results.
I've modified the code to show you only when the delay is happening, see attached. Remember this occurs only the 1st time a run the vi after just opening labview.
Thanks again.
JesusV.
08-24-2005 06:18 PM
08-29-2005 07:16 PM
08-30-2005 04:54 PM
Dear Jesus,
The way you described it I get 254 msec. However, if I completely shut down my computer, restart, and then follow your instructions I get 6.134 seconds. I guess that is how long it takes my computer to load the DAQ drivers. To get around this, you could have an executable that runs with startup that does something easy in DAQ, like reset the driver. Please let me know if you have any questions. Have a great day!
Sincerely,
Marni S.
