Counter/Timer
NI PCI 6602 triggered counters
Dear community,
I have a general question concerning the possibility regarding the measurement capabilities of the NI PCI 6602. Here is what I need: Data of the form [time,count] with an equidistant time intervall of 1ms. It needs to be synchronized to the actual counts to a very high degree. So CAN I trigger a counter readout which does not vary too much around the desired time mark and stays constant over time? How would I do it? Since this specific card does not seem to have a hardware trigger the only possibilty seems to be a software trigger, but if this is possible, how would I accomplish it (possibly using the Daqmx library)?
Thank you very much in advance,
Kai
(6,035 Views)
Dear Kai,
I found a KB which should be interesting for you:
How Do I Count Digital Edges Between a Start and Stop Trigger on an NI 6602 Counter/Timer Board?
http://digital.ni.com/public.nsf/allkb/90B79A96D2E81C2986256B6700551DEE?OpenDocument
For any further questions you can ask.
Best regards
Matijas
(5,967 Views)
Did my informaion helped you ?
Regards
Matijas
(5,948 Views)
Absolutely, thank you very much!
(5,942 Views)
