Counter/Timer
NI6321 triggering laser
Hey guys,
I have an Agilent signal generator triggering my PCIe 6321 card and an ultrasonic pulser. Furthermore I want also to trigger two other devices (two different lasers).
However, since the signal generator has only 2 outputs, I was wondering if I can control the two lasers via the NI card.
The card has four 32-bit counter/timer outputs and I was hoping I could use these outputs to generate two pulse trains in order to trigger my two lasers.
I am quite new to data acquisition, so I am not quite sure if this is possible after all. Also the NI card has to acquire information from a transducer and I am not sure if the card can acquire stuff and generating 2 pulse trains at the same time.
Thanks!
(6,024 Views)
Yes u can.
(5,984 Views)
Thanks, that is good to hear.
One more question: Where can I find some specification in term of the pulse generation of my card?
Like what pulse frequencies I can create and the fall/rise times of the pulses.
(5,982 Views)
http://sine.ni.com/ds/app/doc/p/id/ds-152/lang/de
Keyword: trigger
relatively at the beginning.
cheers, Timo
(5,980 Views)
There are many specs in this link but I have a hard time to find what I need.
Can I generate pulse trains up to 10 kHz, with rise/fall times not exceeding 20 ns with my NI 6321?
(5,957 Views)
