Counter/Timer
Noise filtering - NI 9361
Hello everybody,
I'm using a NI 9361 module to measure the rotation speed of a shaft that is rotating thanks to an electric motor.
I'm facing big noises due to this electric motor; when I launch it, my counter directly measures frequencies up to 1 MHz, even when my shaft is not rotating. I can the see the same phenomena when I'm looking at the edge counting results...
I tried to use the pulse width filter inside my Labview application to filter the signal but I could not find nothing sufficient.
Has anyone ever face this kind of issue, and if so, is there a solution to face it ?
Thank's very much.
(5,882 Views)
Hi gaet.m,
Could yo give us more information about your issue ? What is the amplitude of the noise? How far away from the motor is your NI 9361 and how big is the motor? Do you use it with a CompactRIO or a cDAQ ? Do you have any screenshot of your issue ?
Regards.
(5,864 Views)
Accepted by gaet.m
Are you using a shielded connection to the sensor?  You might also try raising the signal threshold level on the 9361 if you are doing RSE.
(5,680 Views)
hello,please tell me how to solve the problem,thanks
(3,191 Views)
