Counter/Timer
Optical encoder
I have an optical encoder set up on the end of a motor shaft. I want to write a program that will count the pulses from the encoder as the motor rotates and then stop at a certain value.
(5,971 Views)
Good afternoon:
I will need some additional info to have a chance at helpiing you out.
What will be the maximum rpm of your motor shaft?
How many pulses/revolution is your encoder?
Is it an incremental encoder or an absolute encoder?
What interface hardware do you plan to use between the encoder and the PC running Labview?
What version of Labview are you working in?
You can either reply on this forum, or e-mail me at ve3eoq@shaw.ca. The e-mail will be much faster, as I only check into this forum about once/week.
Good luck,
Dave
(5,933 Views)
