Counter/Timer
PCI-6023 is disabled because the BIOS did not give it an IRQ (code 29)
When I go to Control Panel>System>Device Manager and get the "Properties" for my PCI-6023E under "Device status" it says "This device is disabled because the BIOS for the device did not give it an IRQ (Interrupt Request).  (Code 29)  You must enable the device in the BIOS..." I thought I already did that.  Could someone walk me through enabling it in the BIOS to make sure I have done it already? Thanks,
Emily
(3,665 Views)
Hi Emily,
Thank you for posting to the National Instruments forums.
Did this card work previously or did it just recently stop working?  Do other PCI devices work in this computer?  Have you tried this device on another computer?
This will help us figure out if this is an issue with the card, or an issue with the BIOS setting.  Then we can figure out what to do from there.
Thank You,
Nick F.
(3,645 Views)
